Pinging sound: 1996 Toyota Corolla (1.6 L) Auto Trans.
TIMOTHY1027
This car has high mileage (181,778) but has been well cared for. It runs great, plenty of power and compression, no codes, starts & runs fine except for the following:
1. Poor gas mileage.
2. Slight pinging (only at 1/8 throttle opening).
3. Spark plug insulators on new plugs are (bleached) WHITE.
The engine is NOT overheating. I did a complete tune up, checked the EGR and it is working fine, replaced all the vacuum lines, and checked the ignition timing. All good. Still pings. I'm stumped. :-(
Jul 20, 2007 at 10:59 PM
  • 75,988 POSTS
[quote:eaf8c24af4="Timothy1027"]This car has high mileage (181,778) but has been well cared for. It runs great, plenty of power and compression, no codes, starts & runs fine except for the following:
The engine is NOT overheating. I did a complete tune up, checked the EGR and it is working fine, replaced all the vacuum lines, and checked the ignition timing. All good. Still pings. I'm stumped. :-([/quote:eaf8c24af4]
Other causes of detonation include excessive compression, elevated engine operating temperature, preignition, overadvanced ignition timing (spark knock), lean fuel mixture, spark plugs that have too hot a heat range for the application, low octane fuel,
Jul 21, 2007 at 9:42 AM
TIMOTHY1027
[quote:fd6e16af2b="rasmataz"][quote:fd6e16af2b="Timothy1027"]This car has high mileage (181,778) but has been well cared for. It runs great, plenty of power and compression, no codes, starts & runs fine except for the following:
The engine is NOT overheating. I did a complete tune up, checked the EGR and it is working fine, replaced all the vacuum lines, and checked the ignition timing. All good. Still pings. I'm stumped. :-([/quote:fd6e16af2b]
Other causes of detonation include excessive compression, elevated engine operating temperature, preignition, overadvanced ignition timing (spark knock), lean fuel mixture, spark plugs that have too hot a heat range for the application, low octane fuel,[/quote:fd6e16af2b]
The compression range is (215 to 226 psi) on all 4 clylinders (within Toyota specs), the engine operates at normal temps, the ignition timing is 10 degreess BTDC (as/Toyota specs), the spark plugs are correct NGK (OEM specified), I use regular fuel (correct / Owner's Manual).
Jul 21, 2007 at 11:54 AM
  • 75,988 POSTS
Since the EGR checks out-if it has a knock sensor check it-the computer might not be seeing it and not retarding the timing as required
FYI
My Mitchell book says about compression:
Compression: 191psi
Minimum Comp. 142psi
Max. Variation between cylinders 14psi
Jul 21, 2007 at 1:12 PM
TIMOTHY1027
[quote:510d3bf8f6="rasmataz"]Since the EGR checks out-if it has a knock sensor check it-the computer might not be seeing it and not retarding the timing as required
FYI
Compression: 191psi
Max. Variation between cylinders 14psi[/quote:510d3bf8f6]
The engine does not have a knock sensor.
The factory service manual says about compression: "STD...191 psi) or more."
I checked the valve timiing - Dead Nuts.
I replaced the fuel filter (in case of clog).
Still slight ping. I am STILL stumped.
Jul 25, 2007 at 10:46 AM
  • 75,988 POSTS
[quote:4cc998b551="Timothy1027"][quote:4cc998b551="rasmataz"]Since the EGR checks out-if it has a knock sensor check it-the computer might not be seeing it and not retarding the timing as required
FYI
Compression: 191psi
Max. Variation between cylinders 14psi[/quote:4cc998b551]
Still slight ping. I am STILL stumped.[/quote:4cc998b551]
Could be lean mixture-lets try going into the mind of the Computer by checking its parameters on the injector pulses,Coolant Temperature/Oxygen sensors with a Scan Tool.
When you check the ignition timing did you jump the diagnostic connector?
Jul 25, 2007 at 12:48 PM
