Oil Usage Problems in 02 Corolla
ENFAN
I have a 2002 Corolla w/ 77K miles on it. It is using up oil fairly quickly between oil changes. After having it checked at a nearby garage, I was told there are no signs of leakage or of burning oil (the only problem was a rattling noise and finally the oil light came on once and went off - both problems ceased after adding oil). They said to drive it 500 miles and bring it back. I checked the dipstick after hitting 500 miles and there was no oil on it. I added oil and haven't driven it since, but the level on the dipstick has not decreased.
I have heard that, worst case scenario, the car could need a whole new engine. I have also been told that a plugged up vacuum valve has caused such symptoms in Toyotas. Any thoughts??
Feb 6, 2006 at 5:24 AM
BUD4AUBURN
As you can see below your post (1994 losing oil) I have the same problem. I was tool two times that its just the pcv. I replaced it two times. Then a shop person told me I needed a new pcv and have something drilled out. That the car was burning oil inside. I though he did that. But I'm losing oil and I'm going to call him.
Feb 7, 2006 at 5:40 AM
BUD4AUBURN
The local Toyota Service Dept just emailed me and told me what it sounded like was oil pasing by the rings. cost to fix $1770 in my 1994.
Feb 7, 2006 at 10:38 AM
