I had oil in my cooling system. i flushed it out and changed my oil at the same time. now there is oil in the cooling system again and it is cleaner oil. It does not over heat or run any differnt The car has 200,000 miles, what should i get fixed and how hard is it to do it your self. what would happen if i just left it alone? i had the water pump replaced less then a year ago.
Oct 7, 2007 at 2:43 AM
