2003 Toyota Corolla Hit Median
TONY KRASNIQI
Hi everybody.
Last night we had freezing rain in Ottawa. While I was going home, I came to a turn which was very wide but my car would not turn and so I hit a median.
Front tire on driver side seems to be damaged. It had gone back although if I turn the steering wheel both front wheels/tires turn. I did not drive the car after that but I honestly do not know much about cars and I just wanted some advice before I take it somewhere.
Toyota Corolla
4 Door, 2003
94.000 km
Thank you very much
Jan 2, 2007 at 3:18 AM
MMPRINCE3000
  • 133 POSTS
Depends on how hard you hit, but generally you could have bent a control arm, steering arm, strut, damaged a CV shaft, possibly a lower ball joint.
Take it to a dealer or mechanic you trust for an estimate, ask for all the old parts to be returned to you.
Jan 2, 2007 at 5:56 AM
TONY KRASNIQI
hi mmprince3000,
I sent it to the dealership and they told me it would cost me $800 Canadian.
Ball joint was broken, tie rod and a couple of other things.
I have to be honest with you brother, it never crossed my mind to ask for the old parts to be returned and I appreciate you telling me that.
Thank you very much
Jan 2, 2007 at 9:17 AM
Suggested Repair
Have a trusted dealer or mechanic inspect the front suspension and steering after the median impact. The shop found a broken ball joint, a damaged tie rod, and other related parts; replace those components and ask for the old parts to be returned. The quoted repair was about $800 CAD.
Conversation Summary
A 2003 Toyota Corolla slid into a median on icy roads, pushing the driver-side front wheel back while both front wheels still turned with the steering. An expert said the impact could bend a control arm, steering arm, or strut, or damage a CV shaft or lower ball joint, and advised a trusted inspection with old parts returned. The owner later reported a dealership estimate of about $800 CAD for a broken ball joint, tie rod, and other parts.
