Help! Transmission fluid coming out of dipstick tube?!
TOYOTA COROLLA
91COROLLA4AFE
Got a problem with the transmissin fluid backing out of the dipstick tube when traveling for long distance (over 80 miles) on the highway. The car is a 91 toyota corolla in otherwise excellent shape, 165k miles. The transmission is a 3spd automatic. Fluid looks as if it needs changing, a bit dark colored red. Does not seem to be overfull fluid wise. Can the transmission cooler be going out? any suggestions would be great. thank you.
Jul 14, 2007 at 1:59 AM
[quote:e01455c1a0="91corolla4afe"]Got a problem with the transmissin fluid backing out of the dipstick tube when traveling for long distance (over 80 miles) on the highway. The car is a 91 toyota corolla in otherwise excellent shape, 165k miles. The transmission is a 3spd automatic. Fluid looks as if it needs changing, a bit dark colored red. Does not seem to be overfull fluid wise. Can the transmission cooler be going out? any suggestions would be great. thank you.[/quote:e01455c1a0]
If its not overfilled like you said-The tranny is blown-have it pressure tested to ID internal problems.
Jul 14, 2007 at 2:05 AM
91COROLLA4AFE
how could the transmission be blown, I just drove over 500 miles and the transmission shifted perfect??
Jul 14, 2007 at 2:56 AM
[quote:a45d115ff2="91corolla4afe"]how could the transmission be blown, I just drove over 500 miles and the transmission shifted perfect??[/quote:a45d115ff2]
What I meant by blown its messed-up here's some
Fluid flows out the oil filler tube High fluid level Check and correct fluid level
Breather vent clogged, Open breather vent
Clogged oil filter or screen, Replace filter or clean screen (change fluid also)
Internal fluid leakage, Have transmission checked professionally
Jul 14, 2007 at 9:42 AM
