1997 Toyota Corolla No Heat
97COROLLA
My 97 Corolla has no heat. Replaced the heater valve didn't fix the problem. A/C working fine so the air blown ok. Just no hot air ? Seem like the cooling not flowing thru the hose cuz at the engine's end of the hose is very hot but not at the control valve's end ? The thermostat maybe ? Please help.
Thanks.
Aug 31, 2006 at 5:01 AM
BACKYARDMECHANIC
  • 337 POSTS
Dear Corolla,
Sounds like either the thermostat was removed and never replaced(are you the original owner) or struck open. See if the car is reaching normal operating temperature by checking the coolant gauge. If the car is running at normal temp. the thermostat is working which means the heater core is clogged. Remove the heater hoses and run water through one end of the heater core with a garden hose and see if it is clogged. If so flush same and it should fix your problem.
Backyardmechanic :roll:
Nov 9, 2006 at 12:49 AM
Suggested Repair
Confirm the engine reaches normal operating temperature. If it does, the thermostat is likely working and the heater core is clogged—disconnect the heater hoses and flush the core with a garden hose. If the engine stays cool, replace a missing or stuck-open thermostat.
Conversation Summary
The owner of a 1997 Toyota Corolla reports no heat after replacing the heater control valve. Airflow and A/C are fine, but the heater hose is hot at the engine and cool at the valve. The expert advises checking the coolant temperature gauge: if the engine warms normally, flush a clogged heater core; if not, replace a missing or stuck-open thermostat.
