HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Climate Control
Heater
Not Working
SPONSORED LINKS
1996 Toyota Corolla Heater does not work
USERMMA
MEMBER
1996 TOYOTA COROLLA
Heater problem
1996 Toyota Corolla 4 cyl Front Wheel Drive Automatic
The AC works fine but when I put the valve on heat it does not blow hot air.
Tuesday, September 28th, 2010 AT 7:16 AM
MECHANIC
Inspect and test the heater control valve
SPONSORED LINKS
Tuesday, September 28th, 2010 AT 8:01 AM
USERMMA
MEMBER
Thanks, it is fixed. There was a loose control valve wire
Wednesday, September 29th, 2010 AT 10:46 AM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
1996 Toyota Corolla Car Overheated And Heater Blowing...
I Drove My Car Yesterday And I Noticed The Heater Was Blowing Cold Air. A Few Minutes Into My 30 Mile Drive My Car Overheated And Killed. I...
Asked by
MsCecilia
1 ANSWER
1996
TOYOTA COROLLA
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
Heater Problem
Cold Air Blown Out Whilst Heater Is On
Asked by
tigmanie
1 ANSWER
1996
TOYOTA COROLLA
Car Starts Cold But Not Hot
I've Tried To Figure Out Why The Car Starts In That. A.M. But Once Run Won't Restart For At Least Ten Hour I Did I A Fully Rune Up Gapped...
Asked by
Jroy
1993
TOYOTA COROLLA
Heater Not Working Properly
Dear Specialist My Car Listed Above Is An Le With A 1.8l. I Am Anxious That My Heater Core Doesn’t Work Normally, It Doesn’t Blow...
Asked by
Anonymous
2009
TOYOTA COROLLA
No Heat
I Am Not Getting Any Heat Out Of My Car. It Is Only Blowing Cold Air. I Recently Had The Thermostat Changed, But Still Cold Air. I Was...
Asked by
david3399
2006
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Heater Not Working
Blend Door Actuator Replacement
Online car repair manuals
