Fuse Problem
ISLANDBOUY
I have a 95 Corolla 1.8 LE Can a fuse in my FL BLock prevent my car from starting?? It is the ALT 100A fuse
I have power because I get the dinging sound when I insert the key and the dome light works :? :? :?
Nov 26, 2007 at 1:31 PM
  • 75,988 POSTS
have power because I get the dinging sound when I insert the key and the dome light works. Its coming On because its getting power directly from the main link.
The 100amp its the alternator fuse link-test both side of the link for power, dont have power both side its no good.
When the main link goes is just like the battery has been disconnected Nothing at all -no dinging-no dome light nada.
Nov 26, 2007 at 2:16 PM
  • 75,988 POSTS
Inbox :: Message
To: rasmataz
Posted: Tue Nov 27, 2007 8:57 am
Subject: Fuse Problem
So if I change that fuse will my problem be solved you think?
You need to test it, either you look for power with a test light or voltmeter at both side of the fuse- You have a main fusible link and 3 subs.
Nov 27, 2007 at 6:10 AM
ISLANDBOUY
[quote:3591d1182b="rasmataz"]Inbox :: Message
To: rasmataz
You need to test it, either you look for power with a test light or voltmeter at both side of the fuse- You have a main fusible link and 3 subs.[/quote:3591d1182b]
I changed the fuse and it started and works fine.I am going to get the alternator tested tomorrow :D :D :D :D :D
Nov 27, 2007 at 3:03 PM
  • 75,988 POSTS
Thanks for the donation and feedback-Happy Holidays
Nov 27, 2007 at 6:32 PM
