Front wheel squeaking
BPGOODW
I have a 1997 Toyota Corolla and whenever I turn to the right or left I hear a squealing noise coming from the front wheels (passenger side). I also hear this noise when I am coming to a stop without putting any pressure on the brakes (which were replaced recently). Is this a wheel problem? CV joint, bearing?? Any information you could provide would be great! Thanks!
Dec 17, 2006 at 8:26 AM
JESSEHDZ
THE SYMPTONS YOU ARE DESCRIBING, IT MOST LIKELY BE THE PASSENGER SIDE OUTER CV JOINT, DAMAGED CV JOINT WILL MAKE A SQUEALING NOISE WHEN ACCELERATING , DECCELERATING AND ON TURNS.
Dec 18, 2006 at 8:39 AM
