Hello, I own a 1996 toyota corolla ce 1.6 litre engine with 157,000 miles. I have had four exhaust manifolds replaced on this car and it continues to crack all the manifolds in the same spot on the manifolds. All replaced manifolds were new aftermarket, made of heavier castings to be able to withstand cracking. Each time new gaskets were installed and all bolts were torqued to specs. What could be causing this re-curring problem? Thanks for your suggestions.
Nov 25, 2007 at 2:52 PM
