Hello, I have the car listed above S. I changed the head gasket last week, reason, I was driving and suddenly the car overheated, upon inspection I found coolant mixed with the motor oil) and now the car has engine code P2103.
After replacing the head gasket and putting the car back together I topped off the oil and added water instead of coolant for testing. I drove the car and it would not accelerate past 25 MPH. Before taking it to a shop I check compression and got around 170psi on all four cylinders. I also checked spark plugs, coils, and fuel injectors and they all passed with a multimeter. I took it to a shop where they told me I had a bad throttle body, and the exhaust manifold was cracked.
I replaced the throttle body with an Oreily part, and the car was reset at the shop. The car drives fine for 2-3 minutes and then engages limp mode again not going past 25mph, I can turn off the car and it will repeat driving fine for a few minutes and then engage limp mode. If I put on the old throttle body, it won't accelerate well for a few minutes like it does with the new part. What could be the issue?
Jul 18, 2023 at 7:07 AM
