On the acceleration noise, sounds it sound like marbles rattling in a tin can kind of noise. Did the noise start immediatly after timing chain replacement?
Why was the chain replaced.
The brake noise sounds like it may be the pads moving in the caliper bracket if it is more of a click.
If it is a heavier clink, I was start looking for a bad bushing at the control arm, may be ball joint.
With a friend, drive by them and brake reproducing the clunk. They can help narrow down where it is roughly coming from as you stop near them with each wheel in front them. Have them not only listen, watch to see if one of the front wheels shift backward when the clunk happens.
SPONSORED LINKS
Thursday, September 20th, 2007 AT 4:35 AM
