BURNING OIL 20 VALVE....
REGGIEJR
TOYOTA SPRINTER TRUENO,(COROLLA)
1999, 140000KM, 1.6 20 VALVE (AE111)
THE ENGINE WAS TOPPED UP WIT OIL AND 5 DAYS LATER THE OIL WAS AT THE MIN LINE ON THE DIP STICK.
I THINK IT COULD BE THE PISTON RINGS OR THE VALVE SEALS BUT NOT SURE..
ANYONE KNOW WAT I SHOULD DO......
[img:8e307ae150]http://www.2carpros.com/forum/automotive_pictures/85191_levin_side_1.jpg[/img:8e307ae150]
Jul 11, 2007 at 7:56 AM
MMPRINCE3000
  • 133 POSTS
Generally, when seals go bad, you see blue smoke on start-up or under high vacumm i.e. when you are at a high rpm and let off the gas.
Rings that are bad will generally cause blue smoke all the time, especially under acceleration or high load.
Do a compression test to check for bad rings and a leak down test for seals.
Jul 11, 2007 at 11:50 AM
REGGIEJR
THERE IS NO BLUE SMOKE AT ALL, AND THERE IS BAD COMPRESSON IN ALL THE CLYINDERS.... BETWEEN 8 AND 10 BAR!
Jul 12, 2007 at 12:53 AM
