alternator
PMOSADD
I have a 1990 toyota corolla (4 cylinder) that start to stop. I use the jump start to turn it on but after 30 minutes it dies again. Again I used the jump start and drive for 30 minutes and it stop again.
Do you think that there are a likeage in the wiring or it is alternator problem? How could I check?
thanks,
Nov 18, 2007 at 12:04 AM
  • 75,988 POSTS
Get the alternator and battery load tested. Could be the alternator not putting out or the battery is no taking the charge. When it checks out-do a fuel pressure check and comeback with the readings.
Nov 18, 2007 at 12:15 AM
