2003 Toyota Corolla A/C Not Cooling
SLAMKIN
2003 Toyota Corolla, 78k miles, 4cylinder
We went somewhere a/c was good...left location and ac was no longer working. Clutch is not clicking on/off. AC is just blowing hot. About a 3 weeks now have been hearing squeeling under hood like belt was loose. Appears the serpentine belt is only one there is and that is still there.
It is the heat of summer and I just can't afford to take it in the shop. Please help diagnose if you can.
Jun 9, 2007 at 10:19 AM
  • 75,988 POSTS
[quote:e696414788="SLAMKIN"]2003 Toyota Corolla, 78k miles, 4cylinder
It is the heat of summer and I just can't afford to take it in the shop. Please help diagnose if you can.[/quote:e696414788]
Check the pressure could be low in freon R-134a
Jun 10, 2007 at 11:15 AM
Suggested Repair
Check A/C system pressure. Low R-134a refrigerant can keep the compressor clutch from engaging and cause the system to blow hot air.
Conversation Summary
The owner of a 2003 Toyota Corolla says the A/C suddenly stopped cooling, the compressor clutch is not engaging, and only hot air comes out. Squealing had been heard under the hood for about three weeks, but the serpentine belt is still in place. The expert recommends checking whether R-134a refrigerant pressure is low.
