2010 Toyota Corolla
2010 TOYOTA COROLLA
110,500 MILES • 4 CYL • FWD • AUTOMATIC
NAZIR2
LOW RPM OR STOP WHEN AC ON
Oct 26, 2010 at 2:48 AM
Try cleaning out the idle air control valve and also check if it has an idle up solenoid its purpose is to increase the idle speed due to the AC load, also check the charging system-alternator might not be compensating for the additional electrical load from the compressor magnetic clutch
Oct 26, 2010 at 3:34 AM
MMPRINCE4000
  • 8,548 POSTS
As RAZ mentoned these have an idle up solenoid, that increases idle for high load items like AC.
The other problem could be a bad compressor/clutch.
110,000 miles on an 2010?
Oct 27, 2010 at 1:44 AM
