I can,t seem to find the oil filter location on engine
1.8L 4 cylinder [2ZR-FE] ?
Nov 30, 2008 at 3:26 AM
MMPRINCE4000
✓Experienced Mechanic
It should be on front of engine, below intake manifold, next to oil pan. You may have to jack car up, put on stands and look for it. It should be mounted vertically and there is a connector at top of housing for oil pressure sender.
If all else fails, check owners manual, or ask Toyota service for location.
