2009 Toyota Corolla Engine Test - Revving
11,000 MILES • 4 CYL • 2WD • MANUAL
TOMMY7777
I had an issue with cruise control in my car. I was driving about 60 in cruise control and didn't realize that you needed to manually shut it off once you switched gears. I was going down a hill, stepped on the break and put it in neutral. For some reason, the cruise control didn't shut off but I didn't notice. As I was in neutral, the car suddenly revved to the red zone...maybe 7500 and then went right down again. Could this have damaged the engine. The engine seems to be working fine and I know there is a revving limiter. The car was not cold or anything. Of course, I need to find out why the brake didn't shut off the cruise control.
Feb 5, 2010 at 2:32 AM
KHLOW2008
  • 41,812 POSTS
Hi tommy7777,
Thank you for the donation.
Yes, you are correct about the rev limiter and it would prevent the engine from over revving and damaging it. There should be no problem with the engine.
No, you need not manually turn the cruise control off to shift gears. When the brake or clutch pedal is depressed, the cruise control should cut off and seems you are having a problem with that. As vehicle is still rather new and under warranty, you should get it to the nearest dealer to have them look at it.
Feb 5, 2010 at 2:51 AM
MMPRINCE4000
  • 8,548 POSTS
Also have dealer check to see if car is under recall for the gas pedal sticking.
Feb 6, 2010 at 12:05 AM
