2009 Toyota Corolla 4 cyl Two Wheel Drive Automatic
I just changed the rotors and front pads. It now makes a clicking when the car is placed into reverse. It does not make a noise when going to neutral or drive. The click only happens when placed in reverse. Do you know what could be causing this? This was not a problem before I made the rotor and pad changes.
Thank you
SPONSORED LINKS
Sunday, June 13th, 2010 AT 1:46 PM
