2009 Toyota Corolla
OMAR FARID
Electrical problem
2009 Toyota Corolla 4 cyl Front Wheel Drive Automatic
how can i off the tire pressure system light while it is not getting off bz pressing the set button
Aug 11, 2010 at 5:23 PM
  • 75,988 POSTS
INSPECT TIRE PRESSURE WARNING RESET SWITCH
Remove the tire pressure warning reset switch.
Measure the resistance according to the value(s) in the table below.
Standard resistance
RESISTANCE REFERENCE
Tester Connection Switch Condition Specified Condition
E95-1 (INT) - E95-2 (E) ONBelow 1 Ω
and OFF 10 kΩ or higher
If the result is not as specified, replace the tire pressure warning reset switch.
Aug 11, 2010 at 7:29 PM
