wet passenger side rear floor?
52,000 MILES • 4 CYL • FWD • AUTOMATIC
JWLOAR
I have a very wet passenger side rear floor with no explanation for the water. Right front is slightly damp. could this be from condensation somehow??
May 21, 2010 at 7:51 AM
SQM
  • 6,383 POSTS
Typically you will get water on the passenger floor for either having a leak on the windshield seals or evaporator for the A/C system being drained inside the car, due to a clog on the drain that goes to the outside.
The condensation will accumulate while the A/C is operational and it suppose to drain to the outside of the car.
There is a drain on the firewall on the passenger side of the car, for the evaporator. It is likely clogged with dirt/debris.
Clean it out and the issue should go away.
https://www.youtube.com/c/2carpros/featured
Let me know of any questions.
Aug 31, 2021 at 12:15 AM
