2007 Toyota Corolla Smell from OUtside
IME
Smells problem
2007 Toyota Corolla 6 cyl Front Wheel Drive Manual 25K miles
Smell from the outside (fumes, smog, etc.) leaks into the car, especially when it's trailing a big bus or truck that exhausts fumes. What's wrong?
Mar 29, 2010 at 2:58 PM
LEGITIMATE007
  • 5,121 POSTS
well when you have the vents open, whether it on a/c, defrost,heat ,vent. etc. it will pull in whatever is outside the car, because the fresh air vents pulls the fresh air from outside, now when it is in recirculation mode, that is supposed to block the fresh air from coming in, and just refresh what air is in the interior already by sending it through the cabin air filter.
Mar 29, 2010 at 3:12 PM
IME
thanks for the prompt reply. but the vents in my car are usually off/closed. i don't open them. still, the air from the outside seeps into the car.
Mar 30, 2010 at 2:51 PM
LEGITIMATE007
  • 5,121 POSTS
then there is a leak, overtime, some of the mixing doors dont seal as well , or close all the way, this is something that will need to be inspected and replace or resealed. which means the dash needs to come off in order to access the vents and doors, which allow air to enter,
Mar 30, 2010 at 2:59 PM
