2007 Toyota Corolla Need instructions on how to replace the
2007 TOYOTA COROLLA
70,000 MILES • 4 CYL • FWD • AUTOMATIC
BRADROBISON
I need instruction for replacing a front wheel bearing in a 2007 Toyota corolla
Nov 5, 2009 at 2:03 AM
MMPRINCE4000
  • 8,548 POSTS
Toyota bearings are pressed in to knuckle, unless you have a 20 ton press, it is best done by Toyota or trusted shop. The front knuckle has to be removed, bearing pressed out, new bearing pressed in. It is also HIGHLY unusual for a car this new to have a bearing problem. What problems are you having?
https://images.2carpros.com/forum/automotive_pictures/108325_Toyota_wheel_bearing_1.jpg
Nov 5, 2009 at 11:22 PM
