2007 Toyota Corolla maintence warning light
2007 TOYOTA COROLLA
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNDWILSON
How is the maintence warngin light turned off for a 2007 Toyota Corolla
May 30, 2010 at 8:54 PM
OBXAUTOMEDIC
  • CAR REPAIR CONTRIBUTOR
  • 3,711 POSTS
Here is proceedure for vehicle with Smart Key....
DO NOT depress brake pedal when selecting modes to avoid engine from starting.
1.On vehicles with smart key system, make sure smart key is in the vehicle. Pressing the "ENGINE START STOP" switch changes the ignition switch mode as follows:
•First Time - ACC mode (accessories on).
•Second Time - ON mode (power on and all accessories on).
•Third Time - Power OFF mode (indicator light is off).
2.To reset MAINT reminder light after engine oil replacement, place smart key system in power OFF mode with odometer reading showing. Place smart key system in ON mode while holding down trip meter RESET button.
3.Hold trip meter RESET button down for at least 5 seconds. Odometer should indicate "000000" and MAINT reminder light goes out.
With out Smart Key...
1.To reset MAINT reminder light after engine oil replacement, turn ignition switch to OFF position with odometer reading showing. Turn ignition switch to ON position while holding down trip meter RESET button.
2.Hold trip meter RESET button down for at least 5 seconds. Odometer should indicate "000000" and MAINT reminder light goes out.
May 30, 2010 at 9:11 PM
