2007 Toyota Corolla Idle Runs rough
2007 TOYOTA COROLLA
GEMINI1160
Engine Performance problem
2007 Toyota Corolla 4 cyl Automatic 19,000 miles
Hi, My issue is a week or two ago I was sitting at a light, the car was warmed up & I only had the radio on & the idle dipped down almost to a stall & back up quickly. After that I noticed the idle runs rough after it is warmed up what could be the problem. I have been putting in BP'S highest octane gas my last three trips hopeing it might help clean the engine & make it run better. Did not really do much that I can tell.
Any help would be appreciated.
Dec 6, 2009 at 8:04 PM
  • 31,937 POSTS
Hi there, start with checking for a vacuum leak at the inlet manifold, and check the connections of all vacuum hoses in general, also a scan will also be helpful in tracking down this problem, star there.
Mark (mhpautos)
Dec 6, 2009 at 8:10 PM
