2007 Toyota Corolla cooling fans
20,000 MILES • 4 CYL • 2WD • MANUAL
ADAMSSSX
cooling fans run after engine switch off, this setting the alarm off, what can i disable to stop this?
Jan 31, 2010 at 11:46 PM
MMPRINCE4000
  • 8,548 POSTS
Cooling fan relay is stuck, replace it.
The relay is in box in engine compartment and if sticking it should be hot to touch.
Fan switch will also cause fans to run all the time, but will shut off when ign. is turned off.
Jan 31, 2010 at 11:52 PM
ADAMSSSX
main dealer said it could either motion sensor, voltage sensor, impact sensor or a proximity sensor
Feb 1, 2010 at 12:07 AM
MMPRINCE4000
  • 8,548 POSTS
the only device that could power the fan with ign. off is relay.
If you want to disable, pull fuse, which would cut power to relay.
Not sure what dealer is talking about "proximity sensor"?, "motion sensor", "impact sensor"?
Feb 1, 2010 at 12:21 AM
MMPRINCE4000
  • 8,548 POSTS
Here is wiring circuit, but I am not sure you can read it without enlarging, and there are no "proximity sensors" in diagram :) . The fan is also in AC circuit.
https://images.2carpros.com/forum/automotive_pictures/108325_cooling_fan_circuit_corolla_1.jpg
Also what engine does it have?
Feb 1, 2010 at 12:28 AM
