2007 Toyota Corolla Car Stalling
KHANS
Engine Mechanical problem
2007 Toyota Corolla 4 cyl Two Wheel Drive Automatic 62000m miles
hello,
Toyota corolla NZE 1.5 (japan version)
Recently car stalled - always did the necessary maintenance)
Got the following done after stall(routine maintenance):changed spark plugs,flushed brake fluid,flush transmission fluid,clean injectors.
STILL STALLED;
then serviced trottle body.
STILL STALLED;
Changed fuel filter;
STILL STALLED.
Stalls in a topical climate, when engine is either cold/hot. starts back pretty easilt. Diagonistic does not pick up anything
Nov 16, 2009 at 1:15 AM
MMPRINCE4000
  • 8,548 POSTS
If you are not getting any codes, have fuel pressure tested with mechanical gauge.
The NZE engine is sold here in U.S. in the Yaris.
Nov 17, 2009 at 1:29 AM
