2007 Toyota Corolla A/C stops working after countinuous run
39,000 MILES • 4 CYL • FWD • AUTOMATIC
NNCHITGOPKAR
When I run for fewer miles and for fewer distances, A/C works perfectly.
But when I go for a long drive say 500 mils a day, then around driving 300 to 400 mils, A/C switch does not get turned on. Even after trying different combinations, it does not work. Temperature guage does not show any symptons of over heating. It was norrmal.
This has happened twice now. For shorter distances and daily travel, I never had any problem.
Can you please advice on what can be causing this.
Thanks in advance.
Sep 19, 2010 at 2:34 PM
PITCREW94
  • 18 POSTS
Check your AC Comp. Relay. It might not work properly when it's hot..
Sep 27, 2010 at 6:00 AM
