2007 Toyota Corolla
15,320 MILES • 4 CYL • 2WD • AUTOMATIC
LOUISAPEREZ
my fuel trim is +18% and the maf reading is 0.045g/sec. at idle . could i have a bad maf sensor?
Jan 1, 2008 at 12:05 PM
BMRFIXIT
  • 19,053 POSTS
[quote:83ebf34edb="louisaperez"]Engine problem
2007 Toyota Corolla 4 cyl Two Wheel Drive Automatic 15320 miles
my fuel trim is +18% and the maf reading is 0.045g/sec. at idle . could i have a bad maf sensor?[/quote:83ebf34edb]
are you getting check engine light on?
what made you check your trim ?
if so that you need one
and if you r in the states its covered under fed law!!!
Jan 1, 2008 at 12:34 PM
