2006 Toyota Corolla Steering whell wobbles after new tires
2006 TOYOTA COROLLA
56,000 MILES • 4 CYL • 2WD • MANUAL
JOSE2250
I purchased four new tires 1 week ago for my 2006 Toyota Corolla CE. Car was running perfect before I had a local mechanic to install the new tires. After 65m/h, I noticed that Steering whell wobbles. So, I took it back to the shop to have them re-balance the tires. They stated that of the weight on a front tire came off. So, right there in front of me, they re-balanced all four tires. Wobbles stopped @ 65m/h, however, now the wobbles will start @ 70m/h.
THE ONLY difference with the new tires I purchased is size and brand. Original tires were Goodyear integrity P185/65R15. New tires I purchased and installed are Doral P195/65R15. Are the tires the problem?
Jul 16, 2008 at 5:38 AM
KHLOW2008
  • 41,814 POSTS
Hi jose2250,
I believe the tires are the problem since you said it was ok before replacement.
The balancing could have been done badly.
Jul 17, 2008 at 6:05 AM
JOSE2250
Ok, thanks!. I'll try to have someone else to re-balance the tires. If I still have the problem. Maybe I'll change the tires. Thanks for the quick answer.
Jul 17, 2008 at 10:50 PM
