spark plugs I have changed spark plug a few times before?
58,500 MILES • 4 CYL • FWD • AUTOMATIC
WSOP21CHAMP
I have changed spark plug a few times before. But on my 06 corolla i have been unable to find the. Can you tell me where they are.
Aug 23, 2008 at 6:24 AM
SQM
  • 6,383 POSTS
In order to replace the spark plugs, first you will have to remove the black plastic engine cover.
This will expose the top of the engine and you will see the ignition coils on the top.
The spark plugs can be accessed by removing the coils.
Here is a helpful vide that shows exactly what to do:
https://youtu.be/jvWqrAFQQmg
The spark plugs should be torqued at 13 ft.lb.
Feb 1, 2022 at 2:55 PM
