2006 Toyota Corolla Noise of colling fan
2006 TOYOTA COROLLA
35,000 MILES • 4 CYL • 2WD • AUTOMATIC
LUO101823
I just bought a used car, and after I drived more than 1.5 hours continually, I found the cooling fan made a loud noise from time to time, especially in a quiet place, such as in garage. I'm just wondering this is a problem or it is normally for my car. Thanks.
Nov 1, 2008 at 11:10 AM
MMPRINCE4000
  • 8,548 POSTS
Cooling fans on newer Toyota's are usually very quiet. Remove fan assy. and check the fan blade for loosness. Also check for any debris near fan blade or bent shroud.
If blade is OK, then the fan motor may be going bad and would need to be replaced.
Nov 2, 2008 at 12:40 AM
