No Heat
60,000 MILES • 4 CYL • FWD • MANUAL
DAVID3399
I am not getting any heat out of my car. It is only blowing cold air. I recently had the thermostat changed, but still cold air. I was driving over some large speed bumps the other day, and had heat for a few minutes only to lose it again. It's currently -45 where I live, so some heat would be sweet.
Feb 2, 2008 at 8:47 AM
BMRFIXIT
  • 19,053 POSTS
It sounds like you have a temperature blend door actuator that is not working. Here are two guides to help us get the problem fixed and the location of the actuator for your car below.
and
https://www.2carpros.com/articles/car-heater-not-working
Please run down this guide and report back. Cheers
Feb 2, 2008 at 9:24 AM
JWW333
Thanks for the guide my heater core had an air bubble I had to jck the rear of the car up,,, thanks for the guides helped me :) Love this site.
Nov 23, 2018 at 10:32 AM
GENEM058
When I have my heater all the way on. The left side vent blows really hot but when you go down the vents from left to right, the air starts to get cold until you get to the far right vent which it is blowing cold air even though the far left vent is blowing really hot air.
Nov 23, 2018 at 10:33 AM (Merged)
  • 110,248 POSTS
Check to make sure the blend air doors are working properly. If you have duel climate control, there will be 2 doors.
COROLLAPEREZ
2006 Corolla Heater not working properly. On cold days (10º - 33º) it heats up after 25min driving at more than 45mph. Is it the thermomstat?
  • 75,988 POSTS
Check the thermostat, heater core and heater control valve-
