2006 Toyota Corolla ENGINE PROBLEM
218,042 MILES • 4 CYL • 2WD • AUTOMATIC
8580DEAPO
MY CAR WON'T START I CHECKED EVERYTHING ALREADY , I TOOK OFF THE PIL PAN AND I FOUND A BROKEN PISTON ,CAN YOU PLEASE TELL ME WHY THIS HAPPENED.
Oct 2, 2009 at 6:04 AM
MMPRINCE4000
  • 8,548 POSTS
It can happen due to low oil, or from pre-ignition, a condition where the plug fires before TDC.
This can be caused by bad fuel, too much ignition timing (overly advanced), or an extremely lean fuel mixture.
Oct 3, 2009 at 2:18 AM
