2006 Toyota Corolla 'Broken Spring' on bottom 'ashtray' uni
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVEHOFF
My bottom 'ashtray' compartment on the centre column doesn't snap closed. It seems a spring or something is broken.
It is most frustrating trying to keep it closed, because it immediately drops open when I accelerate the car.
Is there a way to repair this?
The dealer says it's a $200 repair!!
Thank you for any advice.
Dave
Jun 12, 2010 at 7:16 AM
  • 31,937 POSTS
If it is a complete ash tray assembly that is required, i would go look in the wreckers yard for one, this will be so much cheaper.
mark (mhpautos)
Jun 12, 2010 at 11:27 PM
GJM25GREGG
Dave- what did you end up doing to fix this? I do not want to spend that much money. I am fairly handy and can fix it on my own if it is not too difficult.
Feb 15, 2011 at 5:50 PM
GJM25GREGG
To clarify, I have the same problem as you did. That is why I asked.
Feb 15, 2011 at 5:51 PM
DAVEHOFF
Hi gjm25gregg,
I've simply lived with it. My wife now drives the car, and she's put her glasses case in it, which keeps the door from rattling around. I may go to a wrecker when the weather warms up.
Feb 15, 2011 at 7:50 PM
QAZWSX
To mhpautos: please explain how to take off the ashtray and put in a new one. Thanks
Mar 16, 2011 at 6:37 PM
  • 31,937 POSTS
Loft out slide tray as if to empty and look up under the top, there are 2 screws there and on some there is a third at the rear, it should be quite straight forward.
Mar 16, 2011 at 7:05 PM
QAZWSX
Can you please attach pictures. I don't know how to empty the ashtray. Thank you
Mar 16, 2011 at 7:17 PM
  • 31,937 POSTS
I have no pic, but just depress the top cover that is spring loaded and pull out.
Mar 16, 2011 at 11:17 PM
