2006 Toyota Corolla air sound high and sometime low
2006 TOYOTA COROLLA
ALOGDI82
Engine Performance problem
2006 Toyota Corolla V8 Four Wheel Drive Manual jgggk miles
I have corolla 2006 .I was driving something was hitting my car from down.the air began to be irregular sound .When I put the gear in neutral sound raised.When I drive slowly it hesitate>
I changed the throttle body and sensor. but still same problem...
thanks,,,
May 3, 2009 at 10:49 AM
MMPRINCE4000
  • 8,548 POSTS
If I understand,
You were driving and something hit the bottom of the car causing an increased idle speed?
Whatever hit you car damaged a component on the engine, you will have to raise car, put on stands and inspect the underside to look for impact area.
May 3, 2009 at 11:35 PM
