car is cutting off when I put it in reverse and back out of my space.
Apr 3, 2009 at 1:52 PM
MMPRINCE4000
✓Experienced Mechanic
Most likely a problem with the idle air control valve. If you intend to work on car yourself, remove IAC and clean it, if problem persists, have car scanned in live data mode and see if IAC is moving when additional loads are put on engine.
