2005 Toyota Corolla Steering Wheel Shimmy When decelearting
2005 TOYOTA COROLLA
94,000 MILES • 4 CYL • FWD • AUTOMATIC
ULTRAHIP
I have an issue with my car, where, if I travel over 60 mph, and I step on the brake to slow down, the steering wheel shimmies back and forth.
I took the car to NTB, and they said that the rear brake drums, pads and rotors needed to be replaced, because they had excessive wear. I gave the okay to that, they did not do a wheel balance or alignment at that time. Well....about $700 later, I still have the problem. The tires are relatively new, so it is not a wear issue. Anyone have any ideas, before I go to my local mechanic?
Thanks!
Jun 9, 2008 at 3:19 AM
KHLOW2008
  • 41,814 POSTS
Hi ULTRAHIP,
The front rotors are the ones causing the problem. Get them refaced or replaced.
Jun 9, 2008 at 5:07 AM
