2005 Toyota Corolla Steering wheel shakes
BREINMAN
Shakes or Wobbles problem
2005 Toyota Corolla 4 cyl Two Wheel Drive Automatic
While I am driving, periodically, my steering wheel jiggles back and forth. It also shakes when I am applying my brakes
May 12, 2009 at 1:44 AM
MMPRINCE4000
  • 8,548 POSTS
May be two seperate problems or a rotor that is warped (other problem may be an alignment issue).
Remove rotors and lay on flat surface like garage floor, if they wobble, they will need to be turned or replaced. If warped and replaced/turned and problem persists, take to an alignment shop.
They can align and check for suspension/steering component failure (ball joints, bearings, bushings).
May 13, 2009 at 1:56 AM
