2005 Toyota Corolla replace headlight
GRZEGORZ
2005 Toyota Corolla
How do I replace headlight?
Feb 18, 2009 at 5:03 AM
MMPRINCE4000
  • 8,548 POSTS
Check your owners manual, but generally the headlight bulb is in a housing that you twist off and pull out, or a plastic ring holds it in place (turn ring counterclockwise and remove electrical connection and bulb).
In some cases you have to remove air intake box or sometimes battery to gain better access.
Feb 18, 2009 at 7:44 AM
