My Toyota Corolla's rear driver-side brake light doesn't work. The bulb itself, is good, but when the brake pedal is depressed, the light doesn't get brighter. The only fuse that the owner's manual calls out is common to both the high brake light and the other sides brake light (which both work fine). Any ideas on what can be wrong or things I can check?
Feb 25, 2009 at 9:41 AM
