2005 Toyota Corolla low idle
2005 TOYOTA COROLLA
TAZZIE
2005 Toyota Corolla 82,000 miles
My car idle is low it's pass between 1 and 0.... so every one says I need a tune up, but does a tune up come with a fuel pump change... and is it a do it yourself project to change the fuel pump and if not how much should I expect to pay for both the tune up and fuel pump?
Jan 4, 2010 at 7:15 AM
MMPRINCE4000
  • 8,548 POSTS
The only tune up items are plugs, air and fuel filter.
Fuel pump is NOT a DIY project, and would only be needed if fuel pressure was low, as measured by a mechanical gauge.
Low idle can be caused by a sticking idle air control valve, or a possible clogged up exhaust.
I would have Toyota or trusted garage check it out.
Jan 5, 2010 at 12:32 AM
