2005 Toyota Corolla leaky condensor flooding rear passenger
40,000 MILES • 4 CYL • FWD • AUTOMATIC
CHAOSGECKO
When I use my ac, the rear passenger floor floods and I cannot find where it is coming in from. Any hints on what I might be able to do to stop the water from coming into the back seat?
Aug 17, 2009 at 12:38 PM
BILLYMAC
  • 2,204 POSTS
HI
here is the prob the ac like your home ac produces water. if you look where your ac lines go into the firewall into your dash. there is a box here heater box this box also houses the ac condensor at the bottom of this box is a hose going outside this is a drain for condensation this hose is plugged and will need to be unplugged so the water drains outside.
you can use air pressure to do this or a coat hanger
billymac
Aug 17, 2009 at 12:50 PM
