HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Idle Rough
2005 Toyota Corolla Idle
HMURPHY
MEMBER
2005 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
108,000 MILES
My goes up and down when stopped at light. Not much but enough to say it idles rough.
Monday, October 19th, 2009 AT 12:45 PM
MMPRINCE4000
MECHANIC
Have Idle Air control valve checked, it controls idle speed. It bypasses air to intake to regulate idle speed. They can sometimes stick.
Also inspect engine for possible vacuum leak.
SPONSORED LINKS
Tuesday, October 20th, 2009 AT 9:37 AM
Please
login
or
register
to post a reply.
Related Engine Idle Rough Content
2005 Toyota Corolla Rough Idle When Braking
Whenever I Come To A Stop In My Car, My Engine Idles Rough For A Couple Seconds Then Idles Normally. It Happens Almost Everytime I Stop....
Asked by
matt35603
2005
TOYOTA COROLLA
GUIDE
Rough Engine Idle
A rough engine idle condition is a common issue that many drivers face often indicating underlying problems within the engine, fuel or ignition system. We have created this...
2002 Toyota Corolla Rough Idle
Idle Is Very Rough At Start Up-after About 30 Seconds It Smooths Out And Runs Great, I Have A Code Po302 Which I Know It Is Misfire Cyl. 2...
Asked by
dave1310
2002
TOYOTA COROLLA
1988 Toyota Corolla Rough Idle
88 Corolla Has Rough Idle And Will Stall. Very Strong Smell With Light Smoke.I Changed Plugs, Wires, D-cap, Rotor, Fuel Filter, Pcv And...
Asked by
tonya toyota
1988
TOYOTA COROLLA
1991 Toyota Corolla Rough Idle - Squeaky Belt-...
Had This Toyaota For About 2 Weeks With 117,000 Miles. I Was Told The Timing Belt Was Changed At 100,000. Came Back From A 5 Hour Drive....
Asked by
wjbrittain
1 IMAGE
1991
TOYOTA COROLLA
Rough Idle
Hi Guys, I Recently Did A Tune Up On The Car Listed Above. I Changed The Spark Plugs Gap 32, Distributor Cap, Wires And Rotor. I Changed...
Asked by
karch1963
1 ANSWER
1992
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
Online car repair manuals
