2005 Toyota Corolla Getting A knock Or a shock When putting
60,000 MILES • 4 CYL • 4WD • AUTOMATIC
IBRAHIM SOBAH
Hello. Im testing a toyota corrola.
And im when i put into reverse gear somekind of knock or maybe some shock is coming.And after starting the car and when the engines temperature rises i feel more sort
of the shock increasing. And when im in parking and when i put the gear to nuteral it starts
again. And i have also diagnosed the car with a system. Here's the reports
Total Codes:003
CODE:001
P0505 Idle Contorl
System
Malfunction
CODE:002
P0710 Trasnmission
Fluid
Temperature
sensor circuit
Malfunction
CODE:003
P0758 Shift solenoid
B Electrical.
Feb 11, 2009 at 2:39 AM
KHLOW2008
  • 41,812 POSTS
Hi Ibrahim,
Thank you for the donation.
It is never easy to noise problems and from your understanding of the noise, do you think it is engine mechanical or external knocking noise cause by something loose and hitting against a vibrating part?
A loose or out of alignment exhaust line, broken mounts etc ould cause knocking noises. The Idle control system is malfunctioning and this would reduce the idling rpm which would cause the engine to vibrate more and that could be the cause it
It could be a bad engine mount causing the shock when shifting into reverse.
P0505 would affect the idling speed and it most probably is cause by a stuck IAC valve located under the throttle body. Cleaning the IAC with carb cleaner might solve the problem.
As to the other 2 other codes, I am unable to find any data about them. Can you please reconfirm if the codes are correct?
Feb 11, 2009 at 5:56 AM
