2005 Toyota Corolla cooling fan not run
72,000 MILES • 4 CYL • 2WD • AUTOMATIC
GUYPRCHINA
my 2005 corolla runs great on road, but when it stop waiting or run at very low speed (<25kmh) for several 10 minutes, the coolant will go to boiling temp and have no cooling fan running. I checked the fues, no problem. What is wrong with the car? Please give me your opinion.
with great thanks!
Jul 25, 2008 at 5:54 AM
  • 75,988 POSTS
Have the coolant temperature sensor, engine coolant temperature gauge switch if it has one and also the fan relay checked out-
Jul 25, 2008 at 6:02 AM
GUYPRCHINA
[quote:ec7afd46f8="rasmataz"]Have the coolant temperature sensor, engine coolant temperature gauge switch if it has one and also the fan relay checked out-[/quote:ec7afd46f8]
thank you very much. the meter on dashboard works fine, in another word, the meter can show me the coolant temp when it goes up. So it is most probablly a bad relay?
Jul 25, 2008 at 6:39 AM
  • 75,988 POSTS
The gauge could be okay but is the computer picking up the signal from the CTS to activate the relay.
Jul 25, 2008 at 7:09 AM
GUYPRCHINA
[quote:46f08449ee="rasmataz"]The gauge could be okay but is the computer picking up the signal from the CTS to activate the relay.[/quote:46f08449ee]
Got it, Thank you!
Jul 25, 2008 at 7:16 AM
