2005 Toyota Corolla computer/electrical/ignition issue
78,000 MILES • 4 CYL • FWD • AUTOMATIC
VOVIE57
turned the engine off, removed key from ignition opened drivers door noticed door open buzzer went off. This never occurs when key is removed. Drivers door is only door buzzing. Noticed parking lights ,dash lights and rear tail lights are on when engine off and key removed. Thought this might be related to ignition switch or computer board related to ignition.
Mar 16, 2008 at 10:16 AM
MMPRINCE4000
  • 8,548 POSTS
When you shut the door, is the door ajar indicator light on?
If so then it is probably the door switch in the door jamb, you would need to replace it.
Mar 16, 2008 at 11:10 PM
