HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Warning Lights
Check Engine Light
2005 Toyota Corolla check engine light is on
MRRONALD
MEMBER
2005 TOYOTA COROLLA
4 CYL
FWD
AUTOMATIC
77,000 MILES
Scan code is P0171 - system too lean. What does that mean? Do I need to replace the O2 sensor, or is it something else?
Thursday, January 14th, 2010 AT 9:38 AM
MMPRINCE4000
MECHANIC
The upstream O2 sensor is reading a lean fuel mixture, this could be an O2 sensor, clogged injector, low fuel pressure.
I would replace the O2 sensor, erase code. If code reappears, then measure fuel pressure with mechanical gauge to start.
I would also add a can of SeaFoam after changing O2 sensor to gas tank.
Friday, January 15th, 2010 AT 10:06 AM
Please
login
or
register
to post a reply.
Related Check Engine Light Content
2005 Toyota Corolla Check Engine Light
The Yellow Check Engine Light Came On. A Code Reader Only Comes Up With 'e' & Does Not Clear The Code. Any Ideas Of What Could Be The...
Asked by
duncamd
1 ANSWER
2005
TOYOTA COROLLA
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Check Engine Light
Why is my check engine or service engine soon turned on? In this guide we talk about what this is associated with this notorious light, what it is used for and what you...
2005 Toyota Corolla Check Engine Light Cruise...
Check Engine Light Comes On, Gas Peddle Is Disabled, Must Shut Car Off, Restart Works Ok For A While. Took The Care Too Auto Zone Or A...
Asked by
carcomputerssuck
1 ANSWER
2005
TOYOTA COROLLA
2005 Toyota Corolla Malfunction Indicator Lamp
The Malfunction Indicator Lamp Came On. My Husband Drove The Car Almost Completly Empty. Then A Day Later The Light Came On. It Has Come On...
Asked by
ASMACAR
1 ANSWER
2005
TOYOTA COROLLA
2005 Toyota Corolla Check Light
I Use To See A Light Display Check And Maint Rqird At Dash Noard
Asked by
OPELOYERU
1 IMAGE
2005
TOYOTA COROLLA
Code 741
Hi, My Car Have The (maint Reqd) Ligth On, I Scan The Car Whith Code Reader And Have Code 741 (torque Converter Clutch Selenoid Circuit...
Asked by
rivera32
1 ANSWER
2005
TOYOTA COROLLA
VIEW MORE
Code Read Retrieval/Clear Honda
What to Do When a Check Engine Light?
Code Read Retrieval/Clear Mercedes Benz
