2005 Toyota Corolla Car Shaking
74,109 MILES • 4 CYL • 4WD • MANUAL
MOSOPKEAT
Good day to you
Keep up the good work you are doing
I observed that my car usually has this jack up intermittently when in motion. It just shakes up when am accelerating on high speed like lets say every 10 minutes. More so when i find myself in traffic, the car begins to shake slightly almost all the time. When i put the gear to N the shaking stops, when i return to D-Drive it starts again. What could be responsible as i have changed my coils, my mechanic has serviced the car and everything seems to perfectly alright except this little issue.After doing this the shaking stops for a while then it starts again but the engine does not go off.
Kind Regards
Thanks
Jul 8, 2010 at 3:15 AM
MMPRINCE4000
  • 8,548 POSTS
Check the trans and motor mounts first.
Jul 9, 2010 at 1:19 AM
