REMOVAL:
Remove the right hand cover under the engine.
Turn the drive belt tensioner clockwise to relieve tension on the belt.
Remove the fan and alternator V belt.
Return the tensioner to the unloaded position.
NOTE
When retracting the tensioner, turn it clockwise slowly in 3 sec. or more. Be sure not to apply force rapidly. After the tensioner is retracted all the way, do not apply force any more than necessary.
INSTALLATION:
Install the belt.
Install the right hand cover under the engine.
Thanks for using 2CarPros.com!
Feb 8, 2009 at 10:35 AM
